Karmack
PC Specification: Core i5-2310/GeForce 210/Windows 8 - x64
Constant crashs when playing AVI files in Windows 8
Wed Dec 12, 2012 1:43 pm
Hello, i'm a brazilian user and fan of Splash Player ---> thanks for PT-BR language in latest version. :D
But, when playing avi files and press button for go for next file, Splash Pro Ex "crash", see in image. please fix it. :|
I use Windows 8 Pro - 64 bits.
Re: Constant crashs when playing AVI files in Windows 8
Wed Dec 12, 2012 8:59 pm
How do you open your video files? Do you use "Open file" (Abrir Arquivo) or double click on your video files?
Karmack
Thu Dec 13, 2012 7:26 pm
radi wrote:How do you open your video files? Do you use "Open file" (Abrir Arquivo) or double click on your video files?
I have used "Open File" and has checked "Open automatically the next file" for play all files in my folder. but the problem is when i click manually for go for the next file.
MirceaForce
PC Specification: i7 5960x gtx 1070 windows 10 v1709 x64
Sat Dec 15, 2012 3:48 pm
Karmack wrote:Hello, i'm a brazilian user and fan of Splash Player ---> thanks for PT-BR language in latest version. :D
same problem here for some avi files & WMV..........I'm using windows 8 pro 64 bit everything is update
Sun Dec 16, 2012 2:47 pm
Thanks for the screenshot. Probably we know what is the cause of the problem and we will be working on a fix.
Karmack
Sun Dec 16, 2012 4:44 pm
radi wrote:Thanks for the screenshot. Probably we know what is the cause of the problem and we will be working on a fix.
Good news...... :P
