proxopotamus
PC Specification: i7/gtx480/Win7 HP
MSI installer
Mon Aug 15, 2011 1:27 pm
Is it possible to get the .msi version of installer for deployment via Active Directory?
Re: MSI installer
Sun Aug 21, 2011 8:11 pm
proxopotamus wrote:Is it possible to get the .msi version of installer for deployment via Active Directory?
Will check out and reply soon.
proxopotamus
Re: MSI installer
Mon Nov 14, 2011 8:46 am
Still no MSI install in 1.7 :/
User
PC Specification: Core i7 920, GTX 750, Win 8.1 Pro x64
Re: MSI installer
Thu Nov 17, 2011 5:03 am
Just run the installer and check out your temp dir for a folder called mirillis.
Open it and you'll find the msi installer.
