iver105
PC Specification: Windows 7 64 bit
Aidio in Vegas pro 12 after exporting
Thu Dec 13, 2012 11:48 pm
Hello Mirillis, i have this problem with the audio after exporting.. My export settings is set on auto and on the highest bitrate, i have tried exporting it with both stereo and wthout.. Well the problem is that after i have exported a file, it will only build half of the sound peaks, so if the clip is 4 minutes it will have sound the first 2 minutes. And i feel that i've tried everything, uncheck every box and check it again, and soooo on. I feel i need some help here, cause we were 3 guys who bought it, and they don't have problem at all. And its kind off irritating me, as im the one whos holding the "team" of making videos.... :) - thanks in advance!
iver105
mp4 files are f*cked?
Tue Dec 18, 2012 7:40 pm
Ok, so i just found out that its with the mp4 files. Because i just tried to record sound only into a WAV file.. So when it is mp4 sound it will only produce the half of the sound peaks. So, do anyone know how i can fix this problem? Please help me :S
Re: Aidio in Vegas pro 12 after exporting
Fri Dec 21, 2012 11:10 am
Try importing the raw AVI file into Sony Vegas.
iver105
Sun Dec 23, 2012 12:06 am
Then the sound will work... But there the problem is, i export it so it won't fill like 2gb..
So i export into mp4 so it fills like 200mb and then it takes the half of the sound from that file.. Thats annoying..
So is there anyway i can export it but still keep the sound in AVI? And thanks for the answer!
iver105
Sun Dec 23, 2012 12:09 am
And where does it save the sound if you "record into seperate audio track"?
Sun Dec 23, 2012 12:24 pm
iver105 wrote:And where does it save the sound if you "record into seperate audio track"?
The second audio track (microphone) is included in the AVI file.
iver105
Mon Dec 24, 2012 12:44 am
So theres no way i can get the whole sound file if i export?
