mongol
PC Specification: Windows 7 64 Bit
How to apply file association?
Tue Aug 16, 2011 8:03 pm
Hello, I downloaded the trial version of Splash Pro to test it and didn't check the "Associate media files with Splash Pro" during installation. I would like to do it know but how? I can't find any option in the application.
Currently I have installed VLC and media files are associated to it.
Thank you.
Bazikcho
PC Specification: AMDx2 2.5Ghz - 4gb - 780G - 1TB - win764
Re: How to apply file association?
Wed Aug 17, 2011 1:50 pm
Select file ( .avi or something u want ) right button menu from mouse > Open with > choose default program > select splash pro :) add check mark to open always this files with splash > click OK
"When I wrote this only God and I understood what I was doing...
Now only god knows !"
mongol
Wed Aug 17, 2011 5:23 pm
Hi, thanks for your reply. However when I right click an avi file for example, I don't get the "Open with" entry :o
P.J
Thu Aug 18, 2011 6:10 am
Bazikcho
Thu Aug 18, 2011 6:12 pm
Do you try with Shift + click ?
Or go to > Control Panel\All Control Panel Items\Default Programs\Set Associations
