SWEG4MER
PC Specification: Nvidia GTX 550 TI OC, Windows 7 Ultimate
[HELP] Splitting up the video!
Sun Dec 16, 2012 11:32 am
I have one question. How can i make Mirillis Action automatically split up the videos for me?
I am doing a walkthrough for a game and want Mirillis to split it up every 30 minute.
I know that there's an option for that in the "upload settings" but it doesn't seems to work...
Is there any way to make it split up the video?
SWEG4MER
Re: [HELP] Splitting up the video!
Thu Dec 20, 2012 7:31 pm
SWEG4MER wrote:I have one question. How can i make Mirillis Action automatically split up the videos for me?
bumpity bumb
Fri Dec 21, 2012 11:06 am
Well, as you mentioned. The only way to split your video is to use the YouTube cut function in Export Settings. I'll do a test clip and see what's going on, but I'm pretty sure this function worked properly last time I checked.
SWEG4MER
Fri Dec 21, 2012 11:29 am
radi wrote:Well, as you mentioned. The only way to split your video is to use the YouTube cut function in Export Settings. I'll do a test clip and see what's going on, but I'm pretty sure this function worked properly last time I checked.
wait what?, export settings? Is that what it means? i though that it would split up the file... like if i record 1 hour and i want to split it up in 30 minutes, that it would give me 2 separate files....
Sun Dec 23, 2012 10:49 pm
Yes, it should be splitting your video files into parts and then upload it to YouTube as parts.
GamerGuy
Mon Dec 24, 2012 3:54 pm
What would be great would be to auto-split it into files of certain length while recording.
