djs
PC Specification: i7 860, Gforce 560ti, Win7 x64
iMon Remote
Thu Aug 18, 2011 12:35 pm
Is there any way of setting up my HTPC with SoundGraphs iMon remote to work properly with Splash Pro ?
I can only get it to launch SplashPro and the only remote control is Play and Pause.
Very often after resuming from Pause the sound is lost and I have to drag the slider back by the Mouse, then sound works again.
Only seem to happen when Pause is pressed on iMon remote and not if Pause is pressed by a mouse.
Sound out of PC is by Optical cable.
P.J
Re: iMon Remote
Sun Aug 21, 2011 10:08 am
djs
Re: iMon Remote
Sun Aug 21, 2011 12:17 pm
I posted in that topic as I also have the Shape remote.
My request here was if anyone has information about Soundgraphs iMon Remote setup for Splash Pro.
A different topic.
Re: iMon Remote
Thu Sep 15, 2011 9:16 pm
Do you experience the problem with sound with all audio codecs or only with ac3 or dts?
djs
Re: iMon Remote
Thu Sep 22, 2011 10:31 am
Sorry Ghost, I can't answer your question now as I've ditched the iMon Remote and software.
Finally got to grips with EventGhost and with the addition of this http://www.simerec.com/ I can use any PC IR remote fully for complete HTPC control.
Sound now plays perfectly when resumed from pause.
Re: iMon Remote
Thu Mar 22, 2012 12:17 am
Thank you for keeping us informed.
