fullgarage
Splash lite - Playlist management not working !
Fri Apr 02, 2010 9:52 am
Hello.
I've just installed spash lite which is great.
However, the playlist window does not seem to work properly :
- impossible to add files
- impossible to remove files
- impossible to clear the playlist
Is it normal ?
My configuration : windows 7 - 64 bits - core i5 520m
Rgds
vivan
Re: Splash lite - Playlist management not working !
Fri Apr 02, 2010 9:58 am
Splash Lite has limited Playlist support - http://mirillis.com/splash.html
I think, that means that such features will be only in Pro version
But it's still possible to create playlist via opening multiple files.
PS Vita, Nokia N8
