bort
PC Specification: Macbook Air 2.13GHz, Mac OS X Lion 10.7
Mono PCM audio from left channel only
Sun Aug 21, 2011 2:48 am
I own 2 licenses (1 for Splash PRO, and 1 for Splash PRO EX).
I've got some files that are encoded with mono PCM audio (e.g. Criterion Blu-rays). Splash PRO is incorrectly labeling these files as Stereo PCM (on the Information screen), so I end up only getting audio out of the left channel in my 5.1 setup.
Other players, e.g. BS Player, properly detect these mono files and simply output the same audio to the left and right channels (which is what I want, of course). Can you please fix Splash PRO so that it mimics this behavior?
Thanks very much.
Re: Mono PCM audio from left channel only
Thu Sep 15, 2011 9:12 pm
bort wrote:I own 2 licenses (1 for Splash PRO, and 1 for Splash PRO EX).
Thanks very much.
Thank for reporting, we will try to fix asap.
