P.J
Blocky/Artifacts while playing MPEG2 HD
Sun Aug 21, 2011 5:59 pm
Recently, I found this problem that occurs many times while playing this video with or without GPU:
Code: Select all
General
Format                           : MPEG-TS
File size                        : 2.38 GiB
Duration                         : 9mn 8s
Overall bit rate                 : 37.2 Mbps
Video
Menu ID                          : 10 (0xA)
Format                           : MPEG Video
Format version                   : Version 2
Format profile                   : Main@High
Format settings, BVOP            : Yes
Format settings, Matrix          : Default
Format settings, GOP             : M=3, N=12
Codec ID                         : 2
Duration                         : 9mn 8s
Bit rate mode                    : Constant
Bit rate                         : 36.0 Mbps
Width                            : 1 920 pixels
Height                           : 1 080 pixels
Display aspect ratio             : 16:9
Frame rate                       : 25.000 fps
Color space                      : YUV
Chroma subsampling               : 4:2:0
Bit depth                        : 8 bits
Scan type                        : Interlaced
Scan order                       : Top Field First
Compression mode                 : Lossy
Bits/(Pixel*Frame)               : 0.694
Stream size                      : 2.24 GiB (94%)
Audio
Menu ID                          : 10 (0xA)
Format                           : MPEG Audio
Format version                   : Version 1
Format profile                   : Layer 2
Codec ID                         : 3
Duration                         : 9mn 8s
Bit rate                         : 384 Kbps
Channel(s)                       : 2 channels
Stream size                      : 25.1 MiB (1%)
Re: Blocky/Artifacts while playing MPEG2 HD
Thu Mar 22, 2012 12:12 am
Thanks for reporting!
Investigating...
