P.J
[Exclusive] Idea for professional Audio Interfaces
Sun Aug 21, 2011 6:29 pm
As you know, Audio Interfaces have separate Stereo output channels:
It would be great if Splash could map each Stereo outputs for full 5.1/7.1 surround format :idea:
Here's my audio interface that has 3 stereo outputs that is capable of 5.1 surround:
kasakka
PC Specification: Core2Quad 3.4 GHz, GTX260, Win7 64-bit
Re: [Exclusive] Idea for professional Audio Interfaces
Mon Sep 05, 2011 3:41 pm
I think this might depend on the audio interface more than the player. At least my Echo AudioFire4 seems to think it's a 4 channel audio card in many games if it's not set to separate stereo output mode.
P.J
Fri Sep 16, 2011 5:06 pm
No, most of the audio interfaces don't support multi-channel.
ocd
Thu Sep 22, 2011 4:20 am
I doubt Splash has anything to do with this. The output hardware (your soundcard/audio interface) is responsible for this)
If you are running analog outs, use high quality signal splitters to your AI and out to your amp. Splash is simply software that processes the audio/video and sends it out to the hardware. How its dealt with after that is upto the hardware.
P.J
Thu Sep 22, 2011 9:40 pm
Look at this:
ocd
Fri Sep 30, 2011 10:51 am
Which program is that screen shot from PJ?
P.J
Sat Oct 01, 2011 2:01 am
Adobe Audition. There're some other programs too.
Thu Mar 22, 2012 12:17 am
I will add this to our list but I do not expect it to be available in the near future.
P.J
Tue Mar 27, 2012 7:07 pm
Mixer mapping would be awesome, Thanks a lot :oops:
