P.J
Micro stuttering while deinterlacing
Fri Aug 26, 2011 7:52 am
I tried to play one of my videos and noticed slight stutter with or without GPU :?
Other players play fine.
Code: Select all
General
Format                           : MPEG-PS
File size                        : 350 MiB
Duration                         : 3mn 25s
Overall bit rate                 : 14.3 Mbps
Video
Format                           : MPEG Video
Format version                   : Version 2
Format profile                   : Main@High
Format settings, BVOP            : Yes
Format settings, Matrix          : Default
Duration                         : 3mn 25s
Bit rate mode                    : Variable
Bit rate                         : 13.7 Mbps
Nominal bit rate                 : 65.0 Mbps
Width                            : 1 920 pixels
Height                           : 1 080 pixels
Display aspect ratio             : 16:9
Frame rate                       : 29.970 fps
Color space                      : YUV
Chroma subsampling               : 4:2:0
Bit depth                        : 8 bits
Scan type                        : Interlaced
Scan order                       : Top Field First
Compression mode                 : Lossy
Bits/(Pixel*Frame)               : 0.220
Stream size                      : 334 MiB (95%)
Audio
Format                           : AC-3
Format/Info                      : Audio Coding 3
Mode extension                   : CM (complete main)
Duration                         : 3mn 25s
Bit rate mode                    : Constant
Bit rate                         : 384 Kbps
Channel(s)                       : 6 channels
Channel positions                : Front: L C R, Side: L R, LFE
Bit depth                        : 16 bits
Stream size                      : 9.39 MiB (3%)
Text #1
ID                               : 224 (0xE0)-608-1
Format                           : EIA-608
Muxing mode                      : A/53 / DTVCC Transport
Muxing mode, more info           : Muxed in Video #1
Stream size                      : 0.00 Byte (0%)
Text #2
Format                           : EIA-708
Re: Micro stuttering while deinterlacing
Thu Mar 22, 2012 12:13 am
Can you please check if it occurs with latest 1.12.1 version?
P.J
Tue Mar 27, 2012 6:33 pm
Splash v1.12.1, Win7 x64 SP1:
T7500,4GB,8600M GT DDR2 256MB v290.61:
GPU: stutter, high video engine load ~85%, less GPU load ~75%
CPU: more stutter, high GPU Load ~85%
WMP12: less stutter than Splash (maybe because of less video quality) but exists.
CPU load is OK for all, so it's because of poor GPU.
G620,8GB,HD6570:
GPU: OK
CPU: De-interlacing problem, visible lines
WMP12: OK
So the only problem is the red line, but not big problem :)
hibaaryan
PC Specification: windows 7
Mon Jan 12, 2015 7:14 am
For the ones like me who couldn`t hide the mouse cursor in Full Screen mode with Hardware Acceleration ON in windows 7 32, i figure it out why i can`t, and in my case is because i had task bar manager opened even minimized... so shut down all programs even the ones that are minimized and problem solved, mouse cursor disappears after ~5 seconds...
dialt1
PC Specification: Windows 7
Mon Apr 13, 2015 7:43 pm
thanks for helpful infotmations :)
