P.J
Another issue with Mpeg2
Fri Aug 26, 2011 8:59 am
I found another issue with Mpeg2 with or without GPU :?
Code: Select all
General
Format                           : MPEG-PS
File size                        : 115 MiB
Duration                         : 3mn 10s
Overall bit rate                 : 5 038 Kbps
Writing library                  : (c) 1998-2005 Womble Multimedia, Inc. / MPEG Video Wizard (09/2005) / Mar  2 2006
Video
Format                           : MPEG Video
Format version                   : Version 2
Format profile                   : Main@Main
Format settings, BVOP            : Yes
Format settings, Matrix          : Default
Format settings, GOP             : M=3, N=12
Duration                         : 3mn 10s
Bit rate mode                    : Variable
Bit rate                         : 4 682 Kbps
Nominal bit rate                 : 6 790 Kbps
Width                            : 720 pixels
Height                           : 576 pixels
Display aspect ratio             : 4:3
Frame rate                       : 25.000 fps
Standard                         : PAL
Color space                      : YUV
Chroma subsampling               : 4:2:0
Bit depth                        : 8 bits
Scan type                        : Interlaced
Scan order                       : Top Field First
Compression mode                 : Lossy
Bits/(Pixel*Frame)               : 0.452
Stream size                      : 106 MiB (93%)
Audio
Format                           : AC-3
Format/Info                      : Audio Coding 3
Mode extension                   : CM (complete main)
Duration                         : 3mn 10s
Bit rate mode                    : Constant
Bit rate                         : 256 Kbps
Channel(s)                       : 2 channels
Channel positions                : Front: L R
Bit depth                        : 16 bits
Delay relative to video          : -80ms
Stream size                      : 5.82 MiB (5%)
Menu
Re: Another issue with Mpeg2
Thu Mar 22, 2012 12:19 am
Thank you again for reporting problem.
