Razerer
PC Specification: AMD Athlon 64 X2 Dual Core 5000+ 2.60 Gz
Stuttering Problem - Completely Solved
Sat Sep 17, 2011 2:08 pm
A friend of mine told me about a software that could help my video stuttering problem because ive always had stutterings during 720p and 1080p movies since I use Motion2. To my surprise 720p and 1080p don't stutter anymore.
its called D3D Overrider ( Direct 3D Overrider ) and its super easy to use.
D3DOverrider is a program that forces triple buffering for direct3d games and video players.
You can download it from here ( http://www.mediafire.com/?2zzymudjfbh )
Basically you just have to add SplashPro.exe into D3Doverrider and then you can try any videos you want.
This is how my D3DOverrider settings look like:
http://postimage.org/image/1pc8zaf6s/
Enjoy ;)
P.J
Re: Stuttering Problem - Completely Solved
Sat Sep 17, 2011 9:26 pm
I prefer to solve it in the player than using third party programs.
There's an option for Triple buffering in video card settings too :roll:
Razerer
Sat Sep 17, 2011 11:25 pm
yea I know but that didnt help my performance too much :)
