Knight
PC Specification: Don't remember... :-D
Weird framerate problem
Fri Sep 23, 2011 11:24 pm
Hi, I noticed that watching some serial in MKV format I have a strange problem: the video play well but sometimes the image got stuck for like 1 or 2 seconds with the audio going on, then it suddenly moves and for 1 or 2 sec is like a fast forward, with the audio normal. Is like it got stuck then got fast for a sec to get in line again with the audio.
Any idea of the reason?
The mkv are 23.976 as framerate and the value I set for motion in Splash is "10".
TV is set 720p@60Hz
Thanks!
P.J
Re: Weird framerate problem
Sat Sep 24, 2011 10:18 am
Please provide more detailed information :?
Can you upload the file?
Knight
Sat Sep 24, 2011 3:49 pm
No I can't, too big. Anyway it happens with many serials so is not relate to one single file.
What other informations/details you need? O.S. Is Windows 7 64Bit. Ram on board is 4GB.
P.J
Mon Sep 26, 2011 4:40 pm
Did you try it without Motion2?
You can also cut a part of it with tsMuxeR.
Knight
Wed Sep 28, 2011 2:43 pm
Yes I tried without it, didn't work... :|
P.J
Sat Oct 01, 2011 2:05 am
Strange :?
