Sconosciuto
PC Specification: Windows 7 Ultimate 32-Bits, MSI 450GTS
Problema con "fxaa-Injector BF3"
Thu Dec 27, 2012 1:12 am
Hi all.
From what I see Fixed "record with FXAA injector" But there is another problem.
I have no idea but ... The Mirillis Action "open, recording or not recording" Disable FXAA-Injector, and I have to close the injector to return the color.
Not only that, when recording with the activated color not recorded! It sees no color injector.
I just wanted to comment and I hope you can solve.
FXAA-Injector: http://www.mediafire.com/?cb7web7w82z2ec5
PS: Sorry for my bad English: (
PSII: I'm using Windows 8
Salu2
Re: Problema con "fxaa-Injector BF3"
Tue Jan 01, 2013 4:14 pm
Contact our support team via support@mirillis.com. Detail your problem and attach the file that you posted here.
SWEG4MER
PC Specification: Nvidia GTX 550 TI OC, Windows 7 Ultimate
Fri Jan 04, 2013 12:32 pm
Sconosciuto wrote:Hi all.
Salu2
Hi, I have been using FXAA injector with Mirillis myself and it is possible that it wont show up on your recordings just because of the simple reason that it is an injector. You see, the injector only serves one purpose and that is too change the colors and shaders on Battlefield. It's not actually made to show up on your recordings but it is possible to happen anyway. I would say that testing it with FXAA off would be a better option as the FXAA also makes you loose some FPS (frames per second).
I hope this helps and please write if you have some more questions.
-SWE
