DJRiful
PC Specification: 3930K, GTX TITAN, Windows 8 Pro 64bit
[BUGS] Action! 1.12.1.0
Fri Dec 28, 2012 1:01 am
1. Secondary Screen Performances
I have nothing running except Chrome + Action! minimized. Action! isn't recording anything but it affects the secondary screen performances. If I drag my browser windows around the desktop. The secondary screen lags or shutters. Primary screen is fine.
Oh by the way, it only happens if the Recording Mode is set to Desktop or Region.
2. Crash when you close or exit Action!
3. Taskbar icon isn't displaying properly
Works fine when you have it running.
DJRiful
Re: [BUGS] Action! 1.12.1.0
Fri Dec 28, 2012 8:11 am
Just so you know I've updated my original post.
DJRiful
Fri Dec 28, 2012 8:18 am
4. Screenshot area: setting will not save when you exit the program.
My temporary solution to solve the crashing error when you exit Action! is to disable the service.
