RuP3r
PC Specification: Q6600 + 8800 GTS
Problem with codecs
Fri Dec 28, 2012 10:22 am
Hi, im a new user to Mirillis, and I can't get Mirrilis Action's .avi's to open in Sony vegas, I installed a lot codecs, normal .avi files do work in sony vegas, but the one I recorded with Action!, and doesn't work, just says "None of files could have been droped in sony vegas" - or something similar. Any Ideas? Thanks.
Re: Problem with codecs
Fri Dec 28, 2012 9:51 pm
Which Sony Vegas version are you using?
Return to “Mirillis Codecs”
