Anynoupy
PC Specification: i7 870, GTX680, 8Go DDR3, 1.5TB, 7x64
Exporting problems
Sat Dec 29, 2012 11:29 am
Hi everyone :)
I tried recording with Action!, no problem apparently, except when trying to export the file to a watchable one ...
The video was recorded in 1080p 30fps, and it lengths about 14mins.
When I try to export it, it seems to work, but at the end of every try I get a file of approx. 65MB, with a length of a minute and a half.
Is it a known problem, and is there a solution please ? Because I can't use any of my recordings at the moment with this problem =/
Thanks for reading and answering,
Feel free to ask if you need any more detail,
Cheers.
Re: Exporting problems
Sat Dec 29, 2012 2:36 pm
which profile are you using? do you use hardware acceleration?
Extragracz
PC Specification: Windows 7
Sat Dec 29, 2012 6:43 pm
Sometimes I've got same problem.
Users browsing this forum: No registered users and 57 guests
