Copnm
PC Specification: Win 7, x64; Dual core; 4GB RAM; GT 430
Splash PRO/EX Wishlist
Tue Jan 01, 2013 5:51 pm
Hello Mirillis family,
First off, I'd like to say how much I LOVE Splash PRO. I believe it is one of the best media player programs available. And with that being said, I'd like to give my 2 cents on helping improve this already fantastic program.
I have made a list of a few suggestions:
1) Add an audio equalizer.
2) Support 10-bit AV files.
3) Support TS files.
4) Add an option to fit the player to the size of the AV file's resolution. (VLC has this feature)
As well as a bug I've noticed:
1) The player doesn't read subs from VOB files.
Thanks for reading,
Neil M
Re: Splash PRO/EX Wishlist
Thu Jan 10, 2013 6:16 pm
Thank you for your suggestions. As for the VobSub format we are planning to expand the subtitles supported format list in future.
Copnm
Fri Jan 11, 2013 4:49 am
Thanks for your reply, Radi.
I hope to see all these integrated in future releases. Hopefully it's not too long a wait. I've been seeing about 75% of the team's effort going into the Action! product and rarely any updates on the Splash programs. But I do thank you for replying and considering.
Thanks for reading,
Neil M
you
PC Specification: core-2-duo;radeon-hd4650;2003svr-x86
Fri Mar 22, 2013 1:05 pm
Could you please add Randomize Button to the playlist, or context menu item for playlist randomize. I've seen that request already here at forum, where answer was something like "we'll implement it", but that was before the new version. No offense, why is that so hard?
Thanks
yellow
PC Specification: Microsoft Windows 8 64-bit. CPU-AMD A8-4
Thu Apr 11, 2013 1:05 pm
Hi Mirillis Guys. I ugraded from Splash Pro Yeserday because Splash Pro/EX Is Excellent. However is it possible to enable the program to convert 4:2:2 VideoFiles .Now that would be realy Excellent. Thanks for a great Converter :D
rambo54
PC Specification: Intel G465 - win7 64 - Intel HD Graphic
Sat Apr 13, 2013 8:22 am
add bitperfect audio stream - Wasapi
