johnelvis
PC Specification: Phenom 955BE, 5770 crossfire, 16Gb RAM,
Action not recording Sound Dirt 3
Sat Jan 05, 2013 8:46 pm
I've been playing around with the software and I noticed that it doesn't record sound in Dirt 3.
All my other games work fine.
I tried various settings and nothing seems to work.
I tried active desktop region, disabling rapture (sound driver from game) and running sound on software mode, Enabling/disabling multi-channel audio recording, in audio balance putting system sounds on 100%.
Am I overlooking something or is it a bug in the Action! software?
johnelvis
Re: Action not recording Sound Dirt 3
Sat Jan 05, 2013 10:59 pm
Same issue with Sleeping Dogs.
Assassin's creed revelations works fine audio wise.
I'll update this post as I find more games...
Fri Jan 11, 2013 2:38 pm
This is odd. As far as I know these both games has been tested and everything was fine. Do you use any unusual audio settings in your games?
DJRiful
PC Specification: 3930K, GTX TITAN, Windows 8 Pro 64bit
Sat Jan 12, 2013 5:19 am
I have to confirm this as well. Asus Xonar DX on UniXonar driver.
Jyden
PC Specification: Windows 8
Thu Jan 17, 2013 12:42 pm
I can't confirm for any of the listed titles here, but I'm having the same issue with Counter-Strike:GO and Borderlands 2 (Won't record in-game sound, but if I use background audio (music) it'll record that). It records both audio and video just fine in Planetside 2. Using an Asus Xonar DGX.
