Splash Lite 1.7.0 & 1.7.1
Sat Nov 05, 2011 3:26 pm
Splash Lite 1.7.0 is now available.
http://mirillis.com/en/products/splash.html
Change Log:
* DVB-T stability improvements
* H.264/AVC software video decoding improvements
* Improved MPEG-2 software decoding performance
* Improved MKV and WMV playback
* MPEG-1 video decoding added
* Improved 25p/50i video playback
* FLAC, AAC, MP3, DTS and LPCM audio playback improvements
* Stereo audio playback on 5.1 analog output fixed
* Support for HDTV video outputs (24p/30p/50p)
* Support for 72/75Hz monitor refresh rates
* Subtitles encoding selection added
* Fixed 100% and 200% windowed video size
* User interface improvements for high DPI Windows settings
* Next/previous file opening improvements for Windows Vista and 7
* Moving the player window by dragging video area added
* Translations improvements
* Vietnamese translation added
* Stability improvements
* Multicore support improvements
* GUI improvements
Re: Splash Lite 1.7.0 & 1.7.1
Thu Nov 10, 2011 5:59 pm
Splash Lite 1.7.1 is now available with important stability improvements!
Change Log:
* IMPORTANT Stability improvements
* Action! recordings playback support up to 8k x 8k (8192x8192)
ertan.kucukoglu
Sun Nov 27, 2011 5:52 am
Under Windows 8 video overlay is forced. I think that causes subtitles to be visible just one frame, and they dissapear right after. It is not possible to read them at all.
ertan.kucukoglu
Tue Nov 29, 2011 4:13 pm
OK, after I install 290.36 version of nVidia dirvers, I started to be able to read subtitles. It seems to be a driver problem.
In the mean time, I have exact same problem with Intel Display drivers on my notebook.
FilozofTR
PC Specification: Intel E8200@3.60 GHz,HD6850,Win 8-64Bit
Thu Jan 26, 2012 7:05 am
ertan.kucukoglu wrote:Under Windows 8 video overlay is forced. I think that causes subtitles to be visible just one frame, and they dissapear right after. It is not possible to read them at all.
Ertan Win 8 64 altında bendede sorun var kardeş, altyazıların arkasında siyah background var? Çözüm buldun mu?
ertan.kucukoglu
Thu Jan 26, 2012 10:01 am
Here is an update for my problem with subtitles.
I do confirm that subtitles are visible under Windows 8 developer preview in certain conditions.
1- Subtitles are not transparent. They cover a rectangular area as black, and text on that black area.
2- Subtitles are not visible if you are not using certain nVidia graphic cards. In my case, I have two graphic cards G210, and 580 GTX. I have visible subtitles as described above using 580 GTX. Unfortunately, I cannot see any subtitle (it appears just for a fraction of time) with G210 adapter with same driver versions on same computer.
kartush
PC Specification: intel e220 nvidia 8500gt windows 8 x64
Sat Mar 02, 2013 11:45 am
in order to get the subtitles background in splash pro(ex) to be transparent just disable video overlay under "settings-video"
