Splash PRO EX 1.12.0 & 1.12.1
Sat Nov 05, 2011 3:28 pm
Splash PRO EX 1.12.0 is now available!
http://mirillis.com/en/products/splashexport.html
Changelog:
* FIC video playback support added for upcoming Action! product
* Detail Boost, Light Boost and Motion² improvements
* Translations improvements
* Stability improvements
aviwil
Re: Splash PRO EX 1.12.0
Sun Nov 06, 2011 12:17 pm
Hi Ghost - good to see you back .
After downloading , and trying to install , I get the error in the attached capture .
Am I the only one with this ?
OK - I reloaded and is OK now .
crl2007
Sun Nov 06, 2011 6:10 pm
Still no subtitle tags. We'll have a surprise for Christmas at least ? :D
aviwil
Mon Nov 07, 2011 12:08 pm
I had trouble running some large m2ts movies ( not all ) . When loading the movie , Splash window would come up , but then just crash . movie wouldn't start .
I went back to v. 1.11.0 and all is OK .
Well , this seems to be solved too - I did an update from the Splash screen when prompted , as opposed to doing a manual download and install of the new version .
Thu Nov 10, 2011 6:02 pm
Splash PRO EX 1.12.1 is now available
What's new in Splash PRO EX 1.12.1?
*IMPORTANT Stability improvements
*Action! recordings playback support up to 8k x 8k (8192x8192)
Gunhed
PC Specification: Pentium 4, 2gb, intel extreme
Re: Splash PRO EX 1.12.0 & 1.12.1
Thu Nov 10, 2011 10:44 pm
To the Mirilis team, well done ! Another excellent version.
Just one request.
Allow picture2 (especially motion2) to be applied prior to export as a preprocessing function.
MaksFearless
PC Specification: ----
Wed Nov 16, 2011 12:19 pm
Ghost,
Now Splash Pro Ex player problem in fullscreen with the video card nvidia GT430 is on the new drivers 285.62-desktop-win7-winvista-64bit-international-whql.exe. Video so slow in full screen mode. After many tests it turned out that the problem is the player with videocard drivers. Fix please.
aviwil
Thu Nov 17, 2011 12:42 pm
MaksFearless - I have the mobile version of the 285.62 drivers on my 460M and it's OK .
Howevr GPU-Z shows a GPU load of 70% - didn't used to .
aviwil
Thu Nov 17, 2011 1:01 pm
MaksFearless - try this :
Re-install the Nvidia drivers , and select Custom , and then "Clean Install" .
Then re-install Splash .
MaksFearless
Fri Nov 18, 2011 10:12 am
I tried everything. The problem rests in the "Deinterlacing". If you press "Auto", then slows down video in Full HD, and not movies, but any football games in Full HD downloaded. Previously, this has never happened before. If you click Disable Deinterlacing, no problem. But on older drivers, everything is fine, but for new drivers - the video is slow.
