CrazyfreakinPanda
PC Specification: Windows Vistax64 Intel Core DUO 2.67 Ghz
My Action does not launch
Thu Jan 10, 2013 8:25 pm
First of all, I downloaded the free trial of Action! on my HP Pavilion dv6 with windows 7 and it worked perfectly well. Now that I want to download the free trial on my HP a6736fr with Windows Vista, it doesn't work.
First, it said that some extensions of the application where missing. Failing to get them, I decided to re-install Action on my Pavilion, and to put it on my a6736 with all the extensions... But when I try to launch it (double click on the "Application" file) it simply does not lauch. It asks for the administrator password, so I put it, but then... nothing. :(
So, if anybody had an idea of how to do this I would really be grateful because it's really, REALLY annoying me. :evil: :cry:
I was thinking of buying it but now, I don't know anymore. :?
SysL
PC Specification: i7-960>EAH6950/2DI2S/2GD5>Win7-x64
Re: My Action does not launch
Sat Jan 12, 2013 5:11 pm
Be sure you have admin rights to the user. I think're using guest account ..disable uac (User Account Control).
CrazyfreakinPanda
Wed Jan 16, 2013 6:27 pm
that is not the solution; i have admin rights...
SysL
Mon Jan 21, 2013 1:43 pm
If you have admin rights, you will not ask you the password.
Right-click the shortcut icon (Mirillis Action)>Click on properties > Click on Advanced > Choose Run as administrator. I hope that helps.
Tue Jan 22, 2013 5:25 pm
Try reinstalling it and cleaning the registry file.
coren0327
PC Specification: i7 4790K, GTX970, 32GBRAM, Win10x64
Thu Jan 24, 2013 1:26 am
Hello, I have the same issue. Application crashes at start. I have tried to uninstall and clean the registery but it does nothing.
Here a windows repport log :
Nom de l’application défaillante Action_x86.bin, version : 0.0.0.0, horodatage : 0x50817889
Nom du module défaillant : Action_x86.bin, version : 0.0.0.0, horodatage : 0x50817889
Code d’exception : 0xc0000005
Décalage d’erreur : 0x00003502
ID du processus défaillant : 0x9ec
Heure de début de l’application défaillante : 0x01cdf9d0beacf0d8
Chemin d’accès de l’application défaillante : C:\Mirillis\Action\Action_x86.bin
Chemin d’accès du module défaillant: C:\Mirillis\Action\Action_x86.bin
ID de rapport : fce8de39-65c3-11e2-a57f-dc0ea1a91468
Nom de l’application défaillante Action_x64.bin, version : 0.0.0.0, horodatage : 0x5081788f
Nom du module défaillant : Action_x64.bin, version : 0.0.0.0, horodatage : 0x5081788f
Décalage d’erreur : 0x00000000000037b9
ID du processus défaillant : 0x1758
Heure de début de l’application défaillante : 0x01cdf9d0beb1d338
Chemin d’accès de l’application défaillante : C:\Mirillis\Action\Action_x64.bin
Chemin d’accès du module défaillant: C:\Mirillis\Action\Action_x64.bin
ID de rapport : fce53471-65c3-11e2-a57f-dc0ea1a91468
With its pair ;
Récipient d’erreurs 81130904, type 4
Nom d’événement : APPCRASH
Réponse : Non disponible
ID de CAB : 0
Signature du problème :
P1 : Action_x64.bin
P2 : 0.0.0.0
P3 : 5081788f
P4 : Action_x64.bin
P5 : 0.0.0.0
P6 : 5081788f
P7 : c0000005
P8 : 00000000000037b9
P9 :
P10 :
Fichiers joints :
C:\Users\ACER\AppData\Local\Temp\WERBFA6.tmp.WERInternalMetadata.xml
Ces fichiers sont peut-être disponibles ici :
C:\ProgramData\Microsoft\Windows\WER\ReportArchive\AppCrash_Action_x64.bin_7351129c29e2e81811cbfceae4de91fbe25559_0d36cbb7
Symbole d’analyse :
Nouvelle recherche de la solution : 0
Statut du rapport : 0
Récipient d’erreurs 3218003377, type 1
ID de CAB : 0
P1 : Action_x86.bin
P2 : 0.0.0.0
P3 : 50817889
P4 : Action_x86.bin
P5 : 0.0.0.0
P6 : 50817889
P7 : c0000005
P8 : 00003502
P9 :
P10 :
Fichiers joints :
C:\Users\ACER\AppData\Local\Temp\WERBFB6.tmp.WERInternalMetadata.xml
C:\ProgramData\Microsoft\Windows\WER\ReportArchive\AppCrash_Action_x86.bin_7eb4c939a955aff22f66d935bc75dff25cad84f_1302cba8
Symbole d’analyse :
As you can see the error occurs on X86 and X64 files. As my system is a 64bit Windows 7 Sp1 I didn't expected it to launch the x86 binaries of the software...
I'm looking forward for a better solution :(
Tue Jan 29, 2013 2:13 pm
When you run Action! you should have 3 processes in your task manager:
Action.exe
Action_x64.bin
Action_x86.bin
If you have more than 3 end them all via taska manger and try running your Action! application again.
coren0327
Wed Feb 06, 2013 9:18 am
Noep, they all start (Action.exe, X86 and X64) but few seconds later stops working (crashes) without notices.
I've installed it on my other computer and it works fine (even if the launch takes a while).
sorrymyfault
PC Specification: windows 7 sp1, r9 270
Sat Aug 22, 2015 4:23 pm
how comes there was never a solution posted? i got the same problem and can't seam to fix it, reinstallingm cleaning reg doesn't work.
i got the 3 processes running but instand of Action.exe i got Action_svc.exe
darkthepro
PC Specification: i7 4700mq , gtx 780m , windows 10 64 bit
Thu Aug 27, 2015 1:34 pm
I have also same problem I have windows 10 64 bit disabled uac, firewall, antivirus , clean install windows or mirillis , tried a lot of ways but couldnt start only in safe mode but doesnt work in normal even latest version
