LuftWaffller
PC Specification: i7 2600k @ 4.4 Ghz - SLI GTX 670 - Win8
Separate Audio Track, and Premiere.
Sat Jan 12, 2013 6:23 pm
been using action for a while, and i have been tryin to use the separate audio track option.
The thing is, it records ok, i can switch tracks in the Action! player, but when i import the footage to Adobe Premiere, there's only on track available, i tried a lot of things already, and i want to know how to add the voice track so i can work in premiere.
Otherwise, im gonna have to record the voice in Audition, and then have to sync it with the footage, wich would make my work a little harder.
Can any of you guys help me?
i thank you in advance.
Re: Separate Audio Track, and Premiere.
Tue Jan 15, 2013 4:15 pm
Adobe products does not support video files with more than one audio track. You can extract the audio track to the WAV file using Virtual Dub for example. Ppen your avi in VD, select from the top menu Audio, then Source audio, then choose Stream 2 (this is your microphone path). And then go to file select Save WAV and choose the file destination, press save and now you have your second audio path seperated from the file for further use.
