proxopotamus
PC Specification: i7/gtx480/Win7 HP
Crashed under the restricted user (AD)
Tue Nov 15, 2011 7:27 am
It crashed at startup every time after the install in Active Directory environment. Running the standart restricted user's account with "run as Administrator" option (and why it need that?).
But it's done if Action run under the logged domain Administrator, no crashes at all.
W7 x64 Pro (W2008 AD).
ps sorry for bad english.
Re: Crashed under the restricted user (AD)
Mon Nov 21, 2011 8:46 pm
Hi, thank you for reporting problem. We have not tested Action! with Active Directory, we will add this to the list to check out. Under standard Windows User Account it works fine in our labs, just requires Admin password to run.
Action! requires administrator rights as it uses low level programming to get the best possible performance.
