StepnSteph
PC Specification: Phenom II X6 1100T, AMD 6970, Win 8 Pro
Auto ReSize?
Mon Jan 14, 2013 9:42 pm
Hello Mirillis and all,
Is it possible to give Splash the ability to automatically switch the size of the player to the resolution of the video? Some videos may be 1280x720 (720p), some 1920x1080 (1080p), others 480x360 and so on. It would be great if the player would automatically adjust itself to the size of the video. For example, in Windows Media Player we have the option "Fit Player To Video". This would be great.
Currently I have manually re-sized it to be about the size of a 720p video, but this causes some issues with other video sizes.
Thanks for your consideration.
Re: Auto ReSize?
Tue Jan 15, 2013 3:37 pm
You can press "1" key on your keyboard. This hotkey is dedicated for 100% video size.
StepnSteph
Re: Auto ReSize?
Tue Jan 15, 2013 4:05 pm
Not quite automatic, but it certainly does the trick. Thanks! 8-)
Return to “General Topics”
