dkgs
PC Specification: cpu:amd 9550, radeon hd3200, win7
No sound after pause
Thu Nov 17, 2011 8:23 am
I tried several versions of the software but I always have the same problem. when resuming to watch a movie after pressing pause, the sound disappear and I have to press stop and then play again in order to get the sound back. This happens sometimes but not always an usually after long watch.
I am using gigabyte motherboard model ga-ma78gm-s2h and amd quad core cpu model 9550.
Thanks for the help.
P.J
Re: No sound after pause
Fri Nov 18, 2011 10:33 pm
What about other video files?
gmit
Sat Nov 19, 2011 12:38 am
dkgs wrote:Hi,
I've always had this probleb with SplashPro...
Note that you can also jump few seconds back and the sound will be restored.
dkgs
Tue Nov 22, 2011 2:31 pm
gmit wrote:
dkgs wrote:Hi,
Thanks for the tip I'll try it but I think that the Dev's should pay attention to this since its a very "old" bug.
P.J - the bug is with all media files.
P.J
Fri Nov 25, 2011 11:02 pm
I don't have this problem :?
dkgs
Wed Nov 30, 2011 2:43 pm
P.J wrote:I don't have this problem :?
maybe its related to the hardware configuration :?:
Bazikcho
PC Specification: AMDx2 2.5Ghz - 4gb - 780G - 1TB - win764
Wed Nov 30, 2011 6:03 pm
I have it sometimes too. I just use back 10 sec to fix it :)
I use 5.1 sound system.
"When I wrote this only God and I understood what I was doing...
Now only god knows !"
P.J
Fri Dec 09, 2011 11:31 pm
I confirm this issue too, very annoying :(
Hope they fix it soon =/
Thu Mar 22, 2012 12:24 am
We cannot reproduce this problem in our labs.
Can you please provide some more info when this happens, does it happen when you press pause/play very fast or only when pause is for a long time?
Whats your audio output settings in Splash audio settings?
Bazikcho
Mon Mar 26, 2012 2:45 pm
5.1 channel :shock:
Sometimes my movie don't have sound when start file ( splash ) but, i am still not stop music from winamp.
I don't think that the problem is in the time btw pauses, probably when some other program try go get sound "channel from windows".
