Styvesant
PC Specification: 3570K, 680, 8gb RAM, Windows 7 (x64)
Splash PRO - not using 5.1?
Thu Nov 17, 2011 8:04 pm
I have a bit of a strange problem.
My speakers are 5.1 but Splash PRO doesn't always seem to use them. Sometimes it just plays the sounds through the front 2 but not the back 2? And this is with the same movie too.
I am a bit of a techie, so I know that I have the latest drivers and all of that, but I cannot seem to fix this one.
Any help? It's just an annoyance really - since the software itself is excellent.
Splash PRO
P.J
Re: Splash PRO - not using 5.1?
Fri Nov 18, 2011 10:36 pm
Are you sure the source is true 5.1?
Did you set 5.1 correctly in windows? You can test it there to ensure.
Nielo TM
Sat Nov 19, 2011 7:29 pm
do you have creative soundcard?
Styvesant
Sat Nov 19, 2011 9:19 pm
P.J wrote:Are you sure the source is true 5.1?
Yes and yes. When I test it, everything seems to be fine. :S
Nielo TM wrote:do you have creative soundcard?
No, no I don't. I have the Realtek HD onboard.
3 out of 5 plays result in the 5.1 not being correctly used.
Splash PRO
Thu Mar 22, 2012 12:21 am
Does this problem occur for the same file with 5.1 audio, I mean once it goes on all speakers and sometimes not?
Styvesant
Fri May 25, 2012 11:18 am
Ghost wrote:Does this problem occur for the same file with 5.1 audio, I mean once it goes on all speakers and sometimes not?
It's really strange, but it does. If I play it once and it doesn't use 5.1, I would have to quit Splash and try again until it does - as trying to re-open the file doesn't work, I would have to actually quit and try again.
Splash PRO
