moamstripes
PC Specification: AMD, Nvidia, Windows 7
[SOLVED] Minecraft and Action! bug.
Sat Feb 02, 2013 6:10 pm
Hello, I recenlty bought Action! and Minecraft. When I start minecraft, everything is normal, but when I start Action! at the same time, minecraft crashes. "Java(TM) Binary has crashed". How to launch the two programs at the same time without any crash ? Please answer me fast.
Re: Minecraft and Action! bug.
Sat Feb 02, 2013 9:26 pm
For some users Action! is not working properly with java. Try using maximized window mode and active desktop region mode in Action! for a workaround.
moamstripes
Sun Feb 03, 2013 9:12 am
It works, but I can't play and record with minecraft in fullscreen ... And I can't record in 1080p ...
daniel44
Sun Feb 03, 2013 9:13 pm
acually there is a fix to this (the fix works if you don't play on full screen mode):
start action! and then run minecraft.
maximize minecraft and then log in to your account and press play.
you will notice that minecraft did not crash.
moamstripes
Mon Feb 04, 2013 6:52 pm
Thanks, It worked !
