aviwil
M2ts Movie Display Problem
Mon Feb 04, 2013 10:31 am
When playing Inception movie from a 31GB m2ts file , the display will disrupt at a few specific points every time , as in the attachment . The only way I've managed to rectify this , is by unticking hardware acceleration in Settings . Tried changing Nvidia driver versions etc. With PotPlayer , I don't get this problem .
Thanks .
Capture 1.JPG (67.46 KiB) Viewed 26394 times
Re: M2ts Movie Display Problem
Mon Feb 04, 2013 11:03 am
Could you provide us a sample file of your video (10mb)? We can provide an ftp for larger files. Which driver versions do you use?
aviwil
Mon Feb 04, 2013 11:21 am
Sample file - I'll see what I can do .
How do I get the attachment image to fit in here right ?
Driver:
Capture 2.JPG (78.99 KiB) Viewed 26388 times
aviwil
Mon Feb 04, 2013 1:32 pm
radi - I have a 90MB file for you - tried to upload it - exceeded limit , I think .
How do I send it easily to your FTP ?
Or some other simple method .
Mon Feb 04, 2013 9:05 pm
aviwil wrote:radi - I have a 90MB file for you - tried to upload it - exceeded limit , I think .
Check your PM box.
aviwil
Tue Feb 05, 2013 6:51 am
radi - the file Inceptioncut_new.m2ts should be on your server .
It's a 20 sec clip - problem appears at 10 sec mark .
Tue Feb 05, 2013 10:38 am
aviwil wrote:radi - the file Inceptioncut_new.m2ts should be on your server .
Thanks. I forwarded your message and file to our lab folks.
aviwil
Tue Mar 05, 2013 4:31 pm
This has been fixed with the new ver. 1.13.2 .
Thanks Mirillis .
Thu Mar 07, 2013 11:15 am
No problem. Thread closed.
