marciomachida
Other PC
Wed Feb 13, 2013 8:54 pm
Currently, today I'm using Action! on my Notebook.
I'm buying a new PC (buying parts yet) to record better with a great GPU and Processor.
I want to take my Action! and send to my PC. But I already use my key with my name on Action from notebook.
How can I continue use my Action! on new PC???
I can remove totally from my notebook if necessary.
Sorry for my english.
Regards.
Re: Other PC
Thu Feb 14, 2013 10:22 am
Uninstall Action! on your notebook before installing it on your Desktop PC.
marciomachida
Re: Other PC
Sat Feb 16, 2013 3:26 pm
radi wrote:Uninstall Action! on your notebook before installing it on your Desktop PC.
If I unistall first, the lisence will work later on desktop?
daniel44
Re: Other PC
Sun Feb 17, 2013 11:37 am
Yes, if you are uninstalling action! the license will be usable again and you will be able to use the license on different computers.
note that you can only use the license one 1 computer at a time so if you want to use the software on a different computer you have to remove action! from the current computer that action! is installed on (when you uninstall action! action! deactivates) and then install install action! on the new computer.
You will have to do this all the time.
