Flaxe
PC Specification: i7-2600K, GTX570, Windows 7 Ultimate x64
Export to Youtube, invalid username/password
Sun Feb 24, 2013 3:07 am
I've been trying to export my gameplay recordings to Youtube by using the built-in export & upload feature in Action!.
It exports the video fine, but when it's going to start uploading to Youtube it says I have entered invalid username or password even if it's correct.
I have entered my gmail address I use for my Youtube account and the password I use for it. I can login to Youtube (website) without any problems. I have also tried to change password to one with only a-z, A-Z, 0-9 but still it don't work (before my password also included special characters). Any ideas?
http://i.imgur.com/R5690yW.png
Regards,
Flaxe
Mu6o
PC Specification: AMD FX-8120, nVidia 560ti, W7P64bit
Re: Export to Youtube, invalid username/password
Sun Feb 24, 2013 12:42 pm
Ther is a password for appications also from gmail if you have set up any.
Flaxe
Sun Feb 24, 2013 2:04 pm
Mu6o wrote:Ther is a password for appications also from gmail if you have set up any.
Not sure if I understood that correctly. But I use my gmail account for my Youtube account, so it's the same login.
Mu6o
Sun Feb 24, 2013 2:16 pm
Gmail let's you type a PROGRAM password, whenever you use gtalk, thunderburd and so on, you must type the password you specified. You are asked to set a password when you connect your phone with the email.
http://support.google.com/mail/bin/answ ... er=1173270
Also it's generated.
Flaxe
Sun Feb 24, 2013 2:32 pm
Mu6o wrote:Gmail let's you type a PROGRAM password, whenever you use gtalk, thunderburd and so on, you must type the password you specified. You are asked to set a password when you connect your phone with the email.
Oh, thank you. I have never seen this page before, or even heard about the application specific passwords :)
The upload worked fine now! Thanks!
Mu6o
Sun Feb 24, 2013 2:43 pm
Glad I was helpfull.
Laurent13
Tue Feb 26, 2013 3:51 pm
Thanks for your help.
:ugeek:
