leviath
PC Specification: i7 920, GTX 660 Ti, 6giga DDR 3
Micro freeze with GTX 660 Ti
Wed Feb 27, 2013 4:06 pm
I just received my new GTX 660 Ti (MSI power edition) and when I capture during the game, it suffers of micro freezes. It films for 5 seconds then it has a micro freeze (less than 1sec) then smooth for 5 sec and again micro freeze, and so on. (exactly 5 seconds each time)
I have the latest version of Mirillis and Nvidia drivers 310.61.
I tried it on several games, same results.
I uninstalled it and installed it 5 times.
Fraps and MSI Afterburner work fine but Mirillis Action is much much better.
mustangmvp
PC Specification: hp phoenix windows 8, 8giga ram
Re: Micro freeze with GTX 660 Ti
Wed Feb 27, 2013 6:26 pm
I , i have the same problem whith action after the next update ...
-hp phoenix
-Intel Core i5 3450
-AMD Radeon HD 7700 Series
The problem comes from the last update of action can cure it fast thank you. ;)
heikki360
PC Specification: i7 3.8, GTX580
Wed Feb 27, 2013 6:39 pm
Same here, i have a GTX580, since today i'm suffering the same problem as you, Fraps works fine. It's really annoying :(
mcatominey
PC Specification: Phenom X6, 660 Ti, Windows 7 64 bit
Wed Feb 27, 2013 6:53 pm
Yes, I have the same problem. However two days ago it worked perfectly with my 660 Ti, now however, any game that I play has these micro freezes. They are evident in the recordings also. I tried recording at different frame rates and that didn't help either. Someone please help!
mustangmvp
Wed Feb 27, 2013 7:27 pm
Hi , i have the same with the last update of action please solve the problem or mirilis please back at the previous verssion
kniff
PC Specification: i7 2600k@4.3Ghz/GTX 970 SLI/16GB RAM
Wed Feb 27, 2013 7:43 pm
Hello, i bought Action! yesterday and got the latest version and experienced the exact same issue! I then re-installed 1.13.0 and it worked just like it used to :) it's only an issue in the newest version. If you download 1.13.0 it does not stutter!
mcatominey
Wed Feb 27, 2013 9:48 pm
Ok, I suffered from the same problem today after the update to 1.13.1.0 and after a conversation with the Mirillis Team on Twitter they provided me with the link for the previous version of the software. This fixed the problem for me. So uninstall your current 'Action' client and install the new one from this link:
Don't worry if you get a warning, I got the same thing. Download it and put in your serial key again and don't install the new version when it prompts you. It should fix the problem. I realise you might be wary of downloading from the link so here is the Twitter conversation: https://twitter.com/MirillisTeam/status ... 2588170241
leviath
Wed Feb 27, 2013 10:02 pm
Thank you very much guys for this response !
I am popular youtuber, so you just saved my life :D
Rikudou
PC Specification: Windows 7
Wed Feb 27, 2013 10:07 pm
mcatominey wrote:Ok, I suffered from the same problem today after the update to 1.13.1.0 and after a conversation with the Mirillis Team on Twitter they provided me with the link for the previous version of the software. This fixed the problem for me. So uninstall your current 'Action' client and install the new one from this link:
Appears to be like this for a lot of people, including myself. Any ETA on a fix?
Thu Feb 28, 2013 12:00 am
We already found a cause of this issue. Fix will be included in 1.13.2 which will be ready within next few hours.
