Akeakamaye
PC Specification: windows 8, nvidia gtx 690, intel i7-3770
Error : failed to create recording file
Fri Mar 01, 2013 3:54 pm
Hi, everyone
I just bought action ! and everytime i try to start recording my desktop, i get this error : failed to create recording file.
I can do the recording in game but not on the desktop, and the limited zone of the desktop get me the same error. But I can do the benchmark.
As in an other topic i tried to change the folder in which the record is made but nothing do. Still the same error.
Today i did the last update, the 1.13.2.0 and nothing change.
I'm on windows 8, and my config is : intel i7-3770, 16GO ram, nivdia gtx 690. I don't think it's a hardware issue :D .
thank's for the future answer.
Re: Error : failed to create recording file
Fri Mar 01, 2013 6:09 pm
Could you post a screenshot when the error occurs?
Akeakamaye
Fri Mar 01, 2013 6:22 pm
Hi, here a screenshot of the error.
screenshot
Desktop 01-03.png (113.23 KiB) Viewed 10450 times
R3M4K3PL
Fri Mar 01, 2013 9:40 pm
Alright, that might be a stupid answer, but...
1. Did you try to select a different folder where your recordings will be held? (I know you wrote that you did, but try a different one, maybe on a different Disc Drive? (etc. D:, C: or other) )
2. Did that happen before?
