darksuN
PC Specification: i5 2500k - GTX 570 Asus - W7 64 bits
Raptr and Action not compatible ?
Fri Mar 01, 2013 11:31 pm
Hi, I use Action! since long months. Never had any problems, it's an awesome software.
I use an other softwere called Raptr, it's a "Xfire like". When I launch a games ( I tried Trine, Shootmania, Max payne 3... ) when Action! and Raptr are launched, the game crash at starts. When Raptr is launhed without Action! It's works, same when I only launch Action! without Raptr.
I think Raptr isn't very famous right now so maybe that a problem which hurt not a lot of gamers...
Does Mirillis know it ? is there a tip ?
Thanks !
Mu6o
PC Specification: AMD FX-8120, nVidia 560ti, W7P64bit
Re: Raptr and Action not compatible ?
Sun Mar 03, 2013 11:43 pm
I don't have that problem. Raptr and Action work fine by each other.
darksuN
Mon Mar 04, 2013 6:12 pm
Hi.
Thanks for your reply.
I found my problem ! You are right. It works perfectly ! The problem was that I'm using Xfire + Raptr + Action, and the video capture was enabled on Xfire + Raptr. So that made crash instantly any games I launched. Now that I've turned off both software with Action on, it's okay!
Solved ! :D
Return to “General Topics”
