DIGG
Error in Tutorial on the website
Mon Mar 18, 2013 9:24 pm
For the record, 64bits applications will install in the folder C:\Program Files\Mirillis\Action! and 32bits applications will install in the folder C:\Program Files (x86)\Mirillis\Action!, so quite the opposite of what your page Setup Intel Quick Sync on PC with NVIDIA Optimus technology @ http://mirillis.com/en/products/tutoria ... setup.html says.
That being said, I have a 64bits operating system, and Action! installed in \program files (x86)\ and once I run Action! I see this:
Which means... the frontend program is 32bits, and it loads a 32 and 64 bits processing part? Care to explain?
Montago
Re: Error in Tutorial on the website
Mon Mar 18, 2013 9:33 pm
I don't think there is a 64 bit version.. i couldn't find it
anyways... the best way to enable QuickSync is NOT to follow their guide, but to install VirtuMVP
ENABLE GPU Virtualization but
DISABLE HyperFormance and VirtualVsync (they will take power out of your iGPU and make the game flicker )
DIGG
Mon Mar 18, 2013 9:51 pm
I have a 1st generation i7 processor, I can't use that, minimum required is 2nd generation cpus lol! :lol:
Montago
Mon Mar 18, 2013 9:57 pm
ohh... thats too bad ... QuickSync works quite good some times.
but if you have enough harddisk , its no problem for you :mrgreen:
DIGG
Mon Mar 18, 2013 10:01 pm
I got 13 hard drives total... and they are mostly full, BUT the very latest I bought still has 1.6GB free! ;)
