DIGG
Export (encoding) feature
Tue Mar 19, 2013 2:06 pm
I tried encoding a capture I did last night, at 1920x1080@60fps, using the Export feature. The resulting encoded file looks great except it's down to 30fps! Why are you forcing the framerate downgrade?
(I chose 1080p High Profile // High, 1920x1080)
Re: Export (encoding) feature
Tue Mar 19, 2013 4:37 pm
If you want to keep 60fps after exporting choose auto profile. Rest of them downgrade the fps count to 30.
Laurent13
Tue Mar 19, 2013 4:40 pm
radi wrote:If you want to keep 60fps after exporting choose auto profile. Rest of them downgrade the fps count to 30.
True :geek:
DIGG
Tue Mar 19, 2013 6:10 pm
Ok, good to know. :geek:
