hzer
PC Specification: Win7, Intel i7 3770 4,4 Ghz, GTX670
MP4 Recording (CUDA, Intel Quick Sync)
Thu Mar 21, 2013 10:21 am
what is the difference when im chosing in the export settings "NVIDIA CUDA" or "INTEL QUICK SYNC VIDEO"
When i record with "MP4 Intel QUICK SYNC VIDEO" is it needed to chose in the export the same or can i chose the nvidia cuda?
Will it have an negative effect on the exporting? (For Rendering i use Adobe premiere not the action programm)
Record Settings
Export Settings
Re: MP4 Recording (CUDA, Intel Quick Sync)
Thu Mar 21, 2013 12:32 pm
You can read more here: http://mirillis.com/en/products/splashe ... mance.html about exporting performance.
hzer
Thu Mar 21, 2013 12:59 pm
Thanks for the info.
I guess the quality Is lower when I'm recording with intel quick sync.
Is that correct ?
vivan
Thu Mar 21, 2013 3:10 pm
hzer wrote:Thanks for the info.
Is that correct ?
Yes, recording into AVI results in better quality (however perfomance can be worse and file size will be bigger).
PS Vita, Nokia N8
