hzer
PC Specification: Win7, Intel i7 3770 4,4 Ghz, GTX670
No Gamesound recorded
Fri Mar 22, 2013 7:00 pm
i only got gamesound when i put the audio device to my boxes not for the asus xonar DX audio.
Any Idea to fix it?
I dont wanna hear the sound from boxes - still wanna hear it from the headset.
If i try any other soundcard it works - what should i do to fix it with my asus xonar dx?
thanks!
Laurent13
Re: No Gamesound recorded
Fri Mar 22, 2013 11:57 pm
Did you downloaded drivers your sound card ?
hzer
Sat Mar 23, 2013 9:04 am
of course - when not i didnt hear anything ^^
I have the actual driver installed.
Montago
Sat Mar 23, 2013 9:16 am
in the old days, when i had a SoundBlaster LIVE card, i had to enable "Record What you Hear" in order to record gamesounds and stuff...
Maybe you need to do the same somewhere ?
Maybe in Windows Sound settings, you need to enable Output as Recording-input ???
hzer
Sat Mar 23, 2013 11:58 am
no thats not the problem.
I only can record sound in Stereo Mix but i cant select Stereo Mix in the Action Software
DIGG
Sat Mar 23, 2013 7:53 pm
Can't you just select the source you want to record?
Sat Mar 23, 2013 10:15 pm
Try disabling all Xonar card special effects and additions.
hzer
Sun Mar 24, 2013 4:51 pm
works now =)
