Kurtsture
PC Specification: C2D 3600, Geforce 240, Win7 32bit
Highbitrate H264 drops frames.
Tue Apr 27, 2010 9:05 pm
hello,
Highbitrate - over 20Mbit H264 720p60 caps in a TS container from various tv channels looses control(?) frames. Every 5 mins it misses a "control" fame so it looks like a second's worth of dataloss - a grey fullscreen. It dosen´t happen in the same spot if you loop/replay a file. But compared to the Overlay DX7/9/EVR render in other players Splash Lite plays them best, ex EVR scrambles the frame order completly :(
This is tested on Win7 32bit (hardware support on XP is a joke compared to win7, everything is smoother in my tests with both ati / nvidia cards - and not only in Splash Lite)
Mentat
PC Specification: AMD 4Core ATI 4870x2 Xfire Win7 64
Re: Highbitrate H264 drops frames.
Wed Apr 28, 2010 9:09 am
the problem is with the adaptive interface link, there is antilepton interference. This in turn is causing the anyon emitter to appear offline to the codec in question. I would try reloading the axionics array, and restart, if that doesnt resolve the issue then please refer to section 12.4.678bh in you Starfleet engineering manual.
