scottiecargo
mp4 files
Sun Mar 24, 2013 11:39 am
hello everyone, i'm new...... i can't get certain mp4 files to play... some mp4 files will play and some wont, any suggestions thank you
Re: mp4 files
Mon Mar 25, 2013 1:00 pm
Where? In Action! player or another players?
scottiecargo
Re: mp4 files
Mon Mar 25, 2013 6:04 pm
i have tryed with the free version splash lite and the splash lite pro... it plays some mp4 files and sum not
Re: mp4 files
Mon Mar 25, 2013 9:25 pm
scottiecargo wrote:i have tryed with the free version splash lite and the splash lite pro... it plays some mp4 files and sum not
Could you post some MediaInfo of the files that are not played in Splash players? MP4 is just a multimedia container format. Maybe your video stream is not supported by Splash.
scottiecargo
Re: mp4 files
Wed Mar 27, 2013 8:53 pm
okay thanks ......
File Name: An Evening at the Improv (4).mp4
File Size: 343 MB
[Container]
Format: FLV (FLV format)
Duration: 00:47:47.29
Bit Rate: 1,005 kbps
[Metadata]
duration: 2867
moovPosition: 36
width: 640
height: 480
videocodecid: avc1
audiocodecid: mp4a
avcprofile: 100
avclevel: 30
aacaot: 2
videoframerate: 30
audiosamplerate: 22050
audiochannels: 2
[Video]
Codec: H264 (H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10)
Codec Tag: [0][0][0][0] (0x00000000)
Picture Size: 640x480 (PAR 1:1, DAR 4:3)
Frame Rate: 29.97 fps
Bit Rate: N/A
[Audio]
Codec: AAC (Advanced Audio Coding)
Channels: Stereo
Sample Rate: 44,100 Hz
Sample Data Format: 16 bits (Integer)
Bit Rate: N/A
File Name: An Evening at the Improv Brad Garret Sammy Davis, Bill Cosby Playing in Las Vegas online .mp4
File Size: 15.8 MB
[Container]
Duration: 00:02:13.53
Bit Rate: 994 kbps
[Metadata]
duration: 134
moovPosition: 36
width: 640
height: 480
videocodecid: avc1
audiocodecid: mp4a
avcprofile: 100
avclevel: 30
aacaot: 2
videoframerate: 30
audiochannels: 2
[Video]
Bit Rate: N/A
[Audio]
Channels: Stereo
Bit Rate: N/A
or this one too ..........
General
Complete name : C:\Users\resources\junk\An Evening at the Improv (11).mp4
Format : Flash Video
File size : 331 MiB
Duration : 46mn 3s
Overall bit rate : 1 006 Kbps
Video
Format : AVC
Format profile : High@L3.0
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Codec ID : 7
Duration : 46mn 3s
Width : 640 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate mode : Constant
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : HE-AAC / LC
Codec ID : 10
Duration : 46mn 3s
Channel(s) : 2 channels
Sampling rate : 48.0 KHz / 24.0 KHz
Compression mode : Lossy
vivan
Re: mp4 files
Wed Mar 27, 2013 9:53 pm
scottiecargo wrote:[Container]
[Container]
Seems like these files are just a renamed .flv files and Splash doesn't support flv (Flash Video).
The only way to playback them using Splash is to remux them to mkv or mp4. For remuxing to mkv you can use mmg.exe from mkvtoolnix (it's free and open source). Remuxing is very fast process and it doesn't change video/audio quailty.
PS Vita, Nokia N8
scottiecargo
Re: mp4 files
Thu Mar 28, 2013 8:20 pm
thanks buddy ... you have been a great help
