Coja
PC Specification: Inter I7 - 3720q, 2.6ghz -NVIDIA GTX 680
About PTT - Any predictions?
Fri Mar 29, 2013 7:52 pm
I´ve read some topics about the PTT button in Action!.
I bought this program because it is better to record the game play of online games.
I think it would be better if Action! have a PTT configuration that you could put a key CTRL to talk, for exemple.
It´s too hard to record your game play and have to use ALT + TAB to access the program and click the red button to start recording, besides the mic open all the time is no good cause any other noise appears in the recording.
There is another famous recording program that you have the PTT option. I was no longer using that, but I have to do narratives in my games and I was forced to re-use.
Are there some estimates of this function be added in Action! ?
Is there any way to get PTT in Action! ?
Thank you and sorry for the inconvenience.
Re: About PTT - Any predictions?
Fri Mar 29, 2013 11:04 pm
Well, there's an option to Record Microphone on button down. And you can start your video recording via F9 hotkey (F10 for audio only recording).
Coja
Sat Mar 30, 2013 2:15 am
Thank you!!
It really is a solution, will leave laborious editing video and I can not record a video after another.
But thanks for show this option
