Eum3
PC Specification: Windows 7
Constantly crashes Minecraft since version 1.13.3
Fri Mar 29, 2013 11:47 pm
It used to be that having Action! open would crash Minecraft only if the game was minimized. This was inconvenient but I could work around it. However with this new update Action! crashes Minecraft no matter what, and so I can't record anything.
Is there any way I can fix this, or revert back to 1.13.2?
Re: Constantly crashes Minecraft since version 1.13.3
Sat Mar 30, 2013 7:20 pm
Due easter egg someone from the tech lab will be able to check your report early on Tuesday. Meanwhile I've sent you a link to 1.13.2. Did you recently updated something more than Action? Minecraft or any drivers maybe?
Eum3
Sun Mar 31, 2013 5:51 pm
Well, the good news is I've gotten Action! to work again. The bad news is I don't know why. I know that Action! 1.13.3 wasn't working with Minecraft Version 1.5 nor version 1.5.1. But when I installed Action! 1.13.2, it wouldn't work with Minecraft version 1.5.1 either. However, it does work with version 1.5! I double checked, and Action! 1.13.3 won't work with Minecraft 1.5.
Also, as a side note, in trying to fix things I installed 64 bit Java alongside my existing 32 bit Java (both version 7 update 17). Changes to Java seemed to have no effect on the problem.
Edit: No changes to drivers that I'm aware of.
Eum3
Tue May 07, 2013 9:46 pm
I believe the problem now was not starting Minecraft with enough memory.
Wed May 08, 2013 12:39 pm
Thanks for the update, all the information will be helpful while our support team is trying to reproduce this problem.
Users browsing this forum: No registered users and 51 guests
