videogramez
PC Specification: i5 2500K, NVIDIA GeForce 560Ti, Win7 x64
Limit or cap the framerate, set maximum fps? For games
Sun Mar 31, 2013 3:24 pm
Is there any way to cap or limit the maximum framerate/fps like MSI Afterburner can?
EDIT: For games, even when not recording.
Re: Limit or cap the framerate, set maximum fps?
Sun Mar 31, 2013 4:15 pm
You can set the following framerate for video recording: 60,50,30,25,24,20,15.
videogramez
Sun Mar 31, 2013 4:39 pm
I meant for the game itself, not the recording.
Sun Mar 31, 2013 6:05 pm
videogramez wrote:I meant for the game itself, not the recording.
Action! is not limiting game FPS and we are not planning similar feature.
Laurent13
Re: Limit or cap the framerate, set maximum fps? For games
Sun Mar 31, 2013 6:07 pm
Yes, when you recording with Action Mirillis, game fps are not fixed, they depend your configuration.
On Minecraft i turn on 200-500 fps when i using Action Mirillis & all depend my stuff :geek:
videogramez
Mon Apr 01, 2013 12:16 am
Yes but as my monitor only has a refresh rate of 60 Hz there's no point in my videocard going over it (and some game menus and entire games like GRAW2 will try to render 200+ fps and nearly melt down your videocard), also it keeps the framerate divisible by two (thus into 30) as much as possible.
MSI Afterburner can do this and it would be a nice feature to have in Action!
alabama20
PC Specification: Core i5 2450M, nvidia GT555M, Win 7 x64
Mon Apr 01, 2013 1:44 pm
videogramez wrote:Yes but as my monitor only has a refresh rate of 60 Hz there's no point in my videocard going over it (and some game menus and entire games like GRAW2 will try to render 200+ fps and nearly melt down your videocard), also it keeps the framerate divisible by two (thus into 30) as much as possible.
Then turn on Vsync in your games and it will cap the framerate, so if you have a 60Hz monitor your FPS will be max 60.
