gnomer
PC Specification: intel i7, Radeon 7970, Win 7 (64b)
Awesomeness with ONE major flaw...
Thu Apr 04, 2013 12:59 pm
Ok, I really love this software and that's why i went from a trial to eventually buying this software.
Now i currently have a smaller issue with wow where i tend to have "lag" spikes in the video stream. I'm thinking though
this is caused by 'DeadlyBoss Mods' (you can Que the lag on the timers of 'dbm'. Anyway, my guess it's gone now.
The thing i'm talking about (and yes, other people have mentioned this before) is the fact that i recorded 40 video's
last night (I always do it like this instead of one massive file) and when i selected them all, exported them it came to
my big surprise that action! stopped after the first file... Imagine the work i'm having now :roll:
So i really do hope that this will get solved in one of the more recent updates because this software is simply
awesome! But that one major flaw provides me with a massive job every time..
Kind regards.
DIGG
Re: Awesomeness with ONE major flaw...
Thu Apr 04, 2013 5:26 pm
To be 100% sure, what you're asking for is an automatic export queue? That would indeed be nice.
gnomer
Thu Apr 04, 2013 5:51 pm
DIGG wrote:To be 100% sure, what you're asking is for an automatic export queue? That would indeed be nice.
Exactly mate! I would have gone to bed and woke up with processed video's. Now i woke up to do 40 video's manually :-)
Rikudou
PC Specification: Windows 7
Sun Apr 07, 2013 12:50 pm
gnomer wrote:Ok, I really love this software and that's why i went from a trial to eventually buying this software.
Kind regards.
http://forum.mirillis.com/viewtopic.php?f=36&t=28458
http://forum.mirillis.com/viewtopic.php?f=36&t=28847
Got any similarities as in these threads? I get the micro stutter/lag/spikes without any addons installed and it is only in WoW this is happening for me.
Tue Apr 09, 2013 11:17 am
We are currently investigating the World of Warcraft issue. This may be related to new expansion pack. Previous versions worked properly.
gnomer
Tue Apr 09, 2013 6:45 pm
I couldn't really say what the problem is, i can tell you then once I've disabled 'DMB' the problem was solved. I never had one millisecond after solving the issue. And i'm recording at 1080p and playing maxed out graphics. Try maybe
lowering your action! settings and see what it does. Also follow the guidelines on how and where to store your captured data.
radi wrote:We are currently investigating the World of Warcraft issue. This may be related to new expansion pack. Previous versions worked properly.
Do you have any news on my issue as wel Radi? :D :lol: ;)
Rikudou
Wed Apr 10, 2013 11:07 am
Sadly already tried that and I've also tried to set the fps in the config file etc, same result and no success :(
