Danielzxzx
PC Specification: Microsoft Windows 7 Home Premium 64-bit
Exported Video Won't Show in Sony Vegas Pro 10
Thu Apr 04, 2013 9:39 pm
So I got the trial version of Action! and everything is working fine with the program except there seems to be an issue with Action! and Sony Vegas.
I exported a video with the highest quality settings and the video loads and looks fine in vlc player but when I opened it in Sony Vegas, the video part didn't load. The audio part sort of loaded though. Only half of the audio part loaded and the other half had no audio.
Can someone help me fix this issue?
lemonade
PC Specification: i5-3570k, GTX 560 Ti, Windows 7 64-bit
Re: Exported Video Won't Show in Sony Vegas Pro 10
Sat Apr 06, 2013 1:21 am
I have the exact same problem. Sony Vegas sees half of the audio and no video. Good thing I haven't made the jump to purchase this. :lol:
What it looks like when I import the video.
My Action! settings.
alabama20
PC Specification: Core i5 2450M, nvidia GT555M, Win 7 x64
Sat Jun 01, 2013 7:02 pm
I have the same issue!
Tue Jun 04, 2013 5:16 pm
Try this:
1) Download (7MB) and install Yamb - http://www.videohelp.com/tools/YAMB
This is an easy-to-use program for fixing MP4 files so they can be accepted by AE 5 but it should also work for Sony Vegas
2) Start the program, click ADD and selected your exported MP4 Action! file.
3) Click "Mux" in right bottom corner.
4) New created MP4 files should work correctly now with your Sony Vegas.
The "muxing" process does not affect the video quality and usually takes few minutes.
