Mesonyx
PC Specification: Win7HomePremium, Nvidia GeforceGTX295
Cannot edit recorded .avi files
Mon Apr 15, 2013 7:41 am
I've been recording gaming sessions with Action! and when I upload the entire file to Youtube, everything is perfect.
I now want to start editing the videos, but when I want to load the files I recorded with Action! into Ulead VideoStudio8, or Cyberlink PowerDirector for editing, I get error messages and the files won't even load. The errors are something like:
"an error occurred while opening this media file in the media library. It may be because the file is broken, an unsupported format, protected video content, or for another reason".
This problem occurs with both video editing programs.
I can load the files in Quicktime or Windows Media and watch them without problems, but for some reason, I cannot load them in video editing programs. Are there certain codecs I need? What else could be causing this issue?
I recorded in .AVI format, I've tried with or without recording audio, in different qualities, I do no use "perfect video match-mode" but each file has the same problem: cannot be loaded for editing.
Any ideas?
Thanks
Daniel
DIGG
Re: Cannot edit recorded .avi files
Mon Apr 15, 2013 1:16 pm
I use VirtualDub to edit (cut) record files. Haven't try with anything else, but vdub does the job, so I'm satisfied. It's very minimal editing though...
Mesonyx
Mon Apr 15, 2013 3:04 pm
Thanks for the info. I downloaded VirtualDub and it works! I only need to cut/trim videos and then paste bits and pieces together anyway so hopefully this program will allow me to do that. I haven't gone into detail with VirtualDub yet, but at least it's loading the files properly and I seem to be able to edit.
Thank you!
Daniel
Mesonyx
Mon Apr 15, 2013 8:22 pm
I also found out I can use the files in Windows Movie Maker, which is actually a great and easy tool for editing movies and putting music to them and stuff, just what I needed
iamegg
PC Specification: I7 2600K 2ndgen / crossfire HD 6870/Win7
Tue Aug 20, 2013 3:31 pm
I'm having a simular problem, recoring BF3 and tried to open the MP4 file with Adobe After effects CS5 and it just makes it crash, i then downloaded VirtualDub but get error:
"The file is of an unknown or unsupported file type"
help? o.o
Wed Aug 21, 2013 10:51 am
iamegg wrote:I'm having a simular problem, recoring BF3 and tried to open the MP4 file with Adobe After effects CS5 and it just makes it crash, i then downloaded VirtualDub but get error:
help? o.o
MP4 with Intel Quick Sync or without?
iamegg
Wed Aug 21, 2013 11:35 pm
help? o.o
The error occures with Quick Sync, so i need to use AVI instead but file sizes are now huge :s
