flashmp3
Intel IVY drivers updated
Wed Apr 17, 2013 1:18 pm
Now no need to tweak a fake display on win8
flashmp3
Re: Intel IVY drivers updated
Wed Apr 17, 2013 1:20 pm
Can you also include high quality for AVI using CUDA in the next release as well ?
I've laptop with iGPU and dGPU. The video mix soft i use can only use the dGPU. When i record with mp4 and quick sync i have big slowdowns. I think it is due to the way the laptop works. I guess when the dGPU is used it takes all the power so both can't be used at the same time as it would on a desktop PC
GamerGuy
Fri Apr 19, 2013 1:39 am
I was hoping this new Intel gfx driver would let me capture using Action & quick sync even when running my gaming laptop in dedicated gfx mode, but apparently not. Action still doesn't give me the quick sync option.
Anyone who knows how to get Action + quick sync to work on an Alienware laptop in dedicated gfx mode please post the answer, thanks.
flashmp3
Fri Apr 19, 2013 7:43 am
GamerGuy wrote:I was hoping this new Intel gfx driver would let me capture using Action & quick sync even when running my gaming laptop in dedicated gfx mode, but apparently not. Action still doesn't give me the quick sync option.
same problem here with my asus ux32vd. I guess we need to wait for an update of Action that works along with the new possibilities given by the new intel ivy drivers
Rawi
PC Specification: i7-3770k, Radeon HD7970, Win 8 x64
Fri Apr 19, 2013 9:04 am
The only change I noticed after installing the new drivers is that the official workaround for using quick sync (the one without attaching new cable to iGPU) now works on Win8.
Previously it was working only for Win7.
But still I need to use 'extend displays' in order for quick sync to show in Action.
flashmp3
Fri Apr 19, 2013 5:45 pm
Rawi wrote:The only change I noticed after installing the new drivers is that the official workaround for using quick sync (the one without attaching new cable to iGPU) now works on Win8.
I think the app need to be updated to support the new driver. Cause the possibility of using quick sync even when the discrete GPU is used is not supported by WIN7. It works only on win8 (i saw it on different websites have a look on google. I'm french and saw it on french websites so perhaps useless for you). So it doesn't work on win7. Perhaps the driver helped to have the mirillis workaround to work but to have the new possibilities offered by the new drivers, they may need to update action
GamerGuy
Sat Apr 20, 2013 1:19 am
I'd be happy if I could get that to work, but when I do the detect displays step it still will only show the AMD 7970M as the extra display. The Intel option doesn't show up even with the new Intel driver. This is on Alienware M17xR4 using the F7 dedicated gfx mode.
Wed Apr 24, 2013 9:29 am
Do you have integrated graphics turned on in your BIOS?
GamerGuy
Wed Apr 24, 2013 7:08 pm
On my Alienware you can toggle between AMD's Enduro mode which defaults to using the integrated gfx but can use the dedicated chip for certain applications (preferences set in AMD Catalyst), OR you can toggle to the dedicated-only mode.
When I'm running in the Enduro mode I can get quicksync to work with Action. Just have to tell Catalyst to run Action on the integrated gfx.
The problem is when I want to run a particularly demanding game in the dedicated mode. In this case Action still doesn't see the quicksync availability, even with the latest Intel driver. Also when I try to detect displays using the workaround trick it only finds the AMD display.
So I'm not sure if this is some limitation of how my laptop works in this dedicated gfx mode or what.
flashmp3
Sat Apr 27, 2013 7:32 am
Any answer regarding my first post ?
