DJRiful
PC Specification: 3930K, GTX TITAN, Windows 8 Pro 64bit
[BUG] Action! 1.14.0 HUD Position
Sun Apr 28, 2013 9:27 pm
The HUD Display Position hot key is broken. It doesn't work.
Re: [BUG] Action! 1.14.0 HUD Position
Mon Apr 29, 2013 2:49 pm
I just checked and it works. Check if you haven't changed your hotkey for a different key. Also check if it's not unticked.
DJRiful
Fri May 10, 2013 9:28 pm
radi wrote:I just checked and it works. Check if you haven't changed your hotkey for a different key. Also check if it's not unticked.
I think it was some other program intercepts my keys. I was forced to use other keys for the moment or the Android app. Thank through!
DJRiful
Thu May 30, 2013 4:03 pm
Actually the bug is on the HUD itself... hotkey didn't do anything so I end up going on the setting where you can click the 6 position you can set. It doesn't do anything as well until I restart Action! to reload the HUD.
The game I'm running is Guild Wars 2.
