TheCharlieGray
PC Specification: AMD P320, ATI HD5470, Win7 HP 64bit
Record Microphone to seperate file
Tue Apr 30, 2013 10:02 pm
Hay,
i would like to record my mic into a seperate file but i dont find any way to achieve this.
I know there is a setting to record it into a seperate line but that is still the same (.avi-)file.
I need the microphone recording in a completely seperate file. (For example a .mp3 or .wma).
Is there any way to achieve this?
Thanks in advance,
Charlie Gray
ShavedApe
Re: Record Microphone to seperate file
Fri May 03, 2013 9:20 pm
You can hit your short cut key to start recording then immediately hit the short cut key to record audio as well that would work.
You could of course just export the audio only in editor though.
TheCharlieGray
Sat May 04, 2013 9:32 am
ShavedApe wrote:You can hit your short cut key to start recording then immediately hit the short cut key to record audio as well that would work.
But the audio recording records the ingame sound as well.
I want two files:
One Videoclip with ingame Sound.
And one Audiofile only with my voice from the headset...
ShavedApe
Sat May 04, 2013 1:53 pm
I want two files:
Why not just export it from within an editor like say vegas? I have no experience of others so i cant say for certain they can do it but I see no reason why they wouldnt.
In and editor you can delete your voice track too once youve exported it and you would then have your two files.
I have to ask why do you need two files?
TheCharlieGray
Sat May 04, 2013 7:49 pm
ShavedApe wrote: Why not just export it from within an editor like say vegas? I have no experience of others so i cant say for certain they can do it but I see no reason why they wouldnt.
I am using TMPGEnc Video Mastering Works 5 and it seems like it can not seperate the two lines from one file :(
So i need two files to mix the volume of my voice and ingame sound afterwards...
Wed May 08, 2013 1:21 pm
TheCharlieGray wrote:Hay,
Thanks in advance,
Charlie Gray
Try using Virtual Dub. Here's a tutorial how to do it, it's in Polish but you will get the gig.
http://youtu.be/rjMY_tCMsK8
TheCharlieGray
Thu May 09, 2013 11:24 am
radi wrote: Try using Virtual Dub. Here's a tutorial how to do it, it's in Polish but you will get the gig.
Thanks!
That does exactly what i was looking for. :)
